Backlit front RAM emblem
MikeG
Livonia La.
To remove grille:
Under the hood there is the plastic cowl that covers the top of the grille that has 6 push clips that has to be remove and the cowl will come off. After that is off you'll see 4 10mm bolts that hold the grille. After they are removed pull out an upwards to get the two bottom clips in each corner to come out.
Remove emblem from grille:
You'll see 4 lock tabs behind the grille. Release the top one first the the two side ones and the emble will come off.
Taking emblem apart:
On the back off the emblem there is 2 holes with snap locks that have to be pushed out wards and the black backin will fold and can then be removed.
Cut a piece of plexiglass in the shape of the black backing and sand with 220 grit to fog the glass.
On the back of the chrome ram you will see 4 slots where the black backing tucks under the chrome. You'll need to shave the plexiglass so it will fit under them.
LED strip:
Place two 6" LED strips as shown
Next you'll have to make a small hole to pass the wire through
Reinstall the emblem:
You'll have to line the outside off the emblem with a 1/8" strip of 3M tape all the way around the emblem and stick in place
Reinstall the grille.
Hook up power:
I tied into the running light on the pass. side. You can do what I did or put it on a switch.
Parts needed:
8"x10" plexiglass $3.00 (Lowes)
Pack of two 6" led flexible strips $12.00 (Autozoo)
18 gauge wire (I had)
Wire taps
The way I did it if you ever get tired of it you can put it back stock without any issues.
Disclaimer : I am in no way responsible for any damage done to your truck if damage accurs. Mod at your own risk.
Happy moddin
tommyguns
chicago
thats awsome If i didn't just pick up a one peace grill id be all over that tomorrow!
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
How does it look during the day with sunlight on it?
MikeG
MikeG
Livonia La.
Not sure i just finished it about a hour ago and it was dark. But if I don't like the way it looks in the day ill pop it back off and tint the plexiglass
Stangshcky12
Oshkosh, WI
5.9 Cummins
You could tint the plexi as well
Lol beat me to it
I've sand blasted plexi before with good results
jbmb06
chester il
That looks awesome!
Sent from my SCH-I535 using Tapatalk 2
Welsh907
2012 Ram Express CC
I'd love to do this. I modified a hitch led to fit in my grill.
MikeG
MikeG
Livonia La.
Thanks for the compliments.
My next lighting project will be step lighting for my nerf bars that wil turn on when the unlock button is pressed.
TylerB
FL
Rudolf with your nose so bright, won't you guide my sleigh tonight?
Docwagon1776
Midwest
Would you not get pulled over since its red
You could in Indiana.
IC 9-21-7-10
Lights visible from front of vehicle; prohibition
Sec. 10. This section does not apply to a vehicle required or authorized under this title to display a red, red and white, or red and blue light that is visible from the front of the vehicle. A person may not drive or move a vehicle or equipment upon a highway with a lamp or device on the vehicle or equipment displaying a red, red and white, or red and blue light visible from directly in front of the center of the vehicle or equipment.
