Backup camera installed.
king99
Lakewood, IL
Was the wiring long enough to make it to the head unit or did you have to add extensions?
OutlawTrucker
OutlawTrucker
Meansville GA
Cummins 6.7
Had to add wire. No big deal. Not sure if it would work with lock pick. I have aftermarket radio. Easy install.
Miami Son
Banned
Port St. Lucie, FL
2012 Ram 1500 Sport Crew Cab
I guess the handle location is fine if all you want to see is your hitch and the ground immediately beneath it.:roflsquared:
king99
Lakewood, IL
How did you run your wire? Where does it come out of the tailgate to make the run to the front? Where did you bring the wire into the cab? Where did you tap into your reverse lights? Sorry for all the question, I'll be doing the install next week when all the parts get here. A DIY post for this would be great if you have the time.
king99
Lakewood, IL
Amazon has a bunch of cams. Be sure to read the reviews though. I picked up one for $28.
OutlawTrucker
OutlawTrucker
Meansville GA
Cummins 6.7
I got mine for $30. I ran the wires along the frame and under the back seat and under the driver side sills to the radio.
I have the power to it tied into the switched red wire on the radio. So I can hit camera on the radio and see behind me going forward.
king99
Lakewood, IL
I'll have to find where to run the wire into the cab from the back seats. Is there a hole to run the wire?
Bigdaddy
2022 3500 Laramie CCLB
6.7L Diesel Cummins
Nice install.
Ocelot
5.7 Non-Etorque
Looks very good. I like your clean look better than my license plate camera. Did you drill the hole in the handle, or buy the handle with the cutout already?
king99
Lakewood, IL
Perfect, crawled under my truck after I posted and that looked to be the best spot. Thank you for the help, I appreciate it. I'm looking forward (or backward if you will, ha lame, but I bet ya laughed a little), to the install. Thanks again.
OutlawTrucker
OutlawTrucker
Meansville GA
Cummins 6.7
Drilled it out. It's only plastic so F it.
:roflsquared: :roflsquared: :roflsquared:
Raadz
