bad front suspension components?
phil frost
phil frost
Angola, ny
@phil frost
Tough to say. I would trying bolting on another set of shocks and double check your tires. How are the swaybar ends?
Swapped the Fox shocks for a new set if skyjacker just to test... Same result.
I'll check sway bar ends next.
Dinky
Oregon
Check to see if your sway bar is fully engaging. That would make the truck move around a lot if it wasn't.
BolletuH
Wyoming
Out of curiosity. Did you torque anything on the suspension while it was suspended in the air?
phil frost
phil frost
Angola, ny
I did not. However I had the dealer install my trackbar and Drag link. Maybe they did. However the new ones have greasable joints and not rubber bushings. But I can certainly check them.
BolletuH
Wyoming
Thuren track bar has a rubber bushing on the frame side. It has to be torqued with the wheels on the ground and under weight of truck. Otherwise the bushing will be constantly loaded with pressure just driving down the road.
SeppW
Northern VA
Hemi 6.4L
yep Fox replaced them. had the same issue. I even tried a different brand only to have the same issue. I am also looking into alignment specs... since I recently replaced the tie rod, drag link and track bar, I had an alignment shop realign the truck. I am checking those specs against what Thuren recommends... particularly, Caster.
I also have an issue with a clicking sounds in my steering column (outside of the cab). Turns out the bearings in lower steering column are going bad, perhaps a flat spot.
Doubt alignment would be causing that. Thuren recommends 0 toe. Factory caster is probably okay with your set up. Most alignment shops don't have a clue on how to set it and get the eccentrics outta whack. Easy way to tell is to check the eccentrics; are they same and looking from the front is one side lower/higher than the other. Another visual check your in the ball park is the drag link and track bar are parallel and the pinion angle to the front drove shaft is level or pretty close to it.
phil frost
phil frost
Angola, ny
I will loosen and retorque tonight to make sure. Thanks.
phil frost
phil frost
Angola, ny
They all look good visually.
SeppW
Northern VA
Hemi 6.4L
I thought so. I figured a bad spring would cause sag. Wasn't sure if anyone ever has a spring go bad as I never had, so I figured I'd ask. The fox shocks came from Thuren with the springs.
The only other thing I could think of is belt is broken in one of the tires. You say this thump or bounce occurs when driving on hardball?
phil frost
phil frost
Angola, ny
only when going over a rough patch. However, it's done this now with the last three sets of tires. 35" General Grabbers, 37" Maxis Razr's and now 37" Cooper Discoverer STT Pros.
phil frost
phil frost
Angola, ny
Before I removed one of the sway bar end links I was inspecting the disconnecting sway bar motor assembly.
Should I have this much play in the coupling with both sway bar end links still connected and the sway bar engaged?
Not sure how to get the vid to upload. But I can rock it by hand about 3/8 to 1/2 inch in both directions... Forward and back.
link to video:
https://vimeo.com/701447345
thkbaron
Minnesota
I'd have to say that's a hard no. lol. At least mine doesn't do that. I'm sure someone else will give you an opinion.
phil frost
phil frost
Angola, ny
I happen to have a non disconnecting sway bar from a 2500. Anyone know if I swap them out and disconnect the sway bar motor, are there othe electronics tied to that? Will I have a warning light come on?
Would be temporary to make sure this is the problem and until I sack up to buy a replacement.
thkbaron
Minnesota
Surprised you aren't getting more comments. There were plenty earlier. haha I unfortunately don't know the answer to your question.
SeppW
Northern VA
Hemi 6.4L
Most likley the SERV 4WD will probably light up. You could secure the motor assy to frame temporarily. Did you disconnect the end links and try driving it? Some do, alleging handling is improved. Seems like you would get a bit more body roll, but a search here or on the other PW forum has discussions on smart bar swaps to a manual set up, bypass kits, etc, etc.
phil frost
phil frost
Angola, ny
Thanks. I figured it wouldn't be a straightforward swap. Some s@@t came up and I haven't had time to get back under to remove the end links just yet. This week though I should have time.
crazy jerry
WY
the links didnt wear out. they got destroyed because the mickey mouse aftermarket suspension changed all the angles of everything
thkbaron
Minnesota
that end link looks perfect! What are you saying!? lmao!
