I have a 94 ram 1500 with a 3.9L and a 5 speed manual. I recently replaced the clutch in it and while i had the engine out, I put a timing set and tensioner in because it didn't come factory with one. Once i got it back in the truck and hooked everything back up, and fired her up it started shaking real bad and on acceleration it has a pop in the top in. Checked for vaccum leaks and replaced the crank sensor with no avail. And the timing marks got lined up exactly where they were when i took it apart. Could the tensioner cause the timing to be a tooth off? Any help/advice would be appreciated.
