Bad whine when driving
Ramtruck16
Blue Springs Mo
my 16' Ram has just started to make this really loud whining sound when driving and while at idle, it is not the A/c as it makes no diffrence if its on or off. The truck has 36k. what could this be? I have to take it in because my cruise control doesn't work right so id like to do some troubleshooting of my own. Any help would be appreciated.
Fitz-0518
Veteran 66-68
Central California
2018 2500. 2018 1500
Check your serpentine pulleys and tension pulley. Easy to do. Move your belt out of the way. Hand spin/turn the wheels. If they do not move very smooth or make a grating noise, you found your problem. An old mechanic trick. While it is running carefully spray WD 40 on the bolt/bearing part of the pulley. If it quiets you found it.
Pull Ya
Cedar Creek, Tx
^^^^^ This sounds like a good place to start-----------unless you just recently installed a supercharger----LOL
Jay
huntergreen
Marine Corps Navy Badge
I would check the alternator and water pump along with the pulleys.
RamCares
n/a
n/a
While you're at the dealer, be sure to let us know if an additional layer of assistance is needed. We're available via direct message and would be happy to help.
Jasmine
Ram Social Care Specialist
dexter
Banned
Could be an exhaust related issue also.
Check fluid levels in all areas.
Ramtruck16
Ramtruck16
Blue Springs Mo
Fixed the problem, the breather hose was loose and was making noise against the airbox, i reconnected the hose and the noise went away..
it seems like someone knocked it loose when i had it in the dealer for an oil change.
Fitz-0518
Veteran 66-68
Central California
Love the no deep dive sophisticated complicated expensive fix's. Good outcome thanks for the conclusion.
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Thanks for the Update ! Glad it was a easy fix !
Ramm5.7
So Cal
2019 Ram 1500 Classic Bighorn
The last bad whining noise I had I push her out the door :O Now no more whine :O.. But really I am no help but will be following to see what you find
My thought exactly when I saw the thread headline.....
If you have a bad whine, get rid of her...:badidea: :signs6:
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Well I did slow down to 25 MPH and went through a puddle to soften the fall so I would not be a total ass hat lol :O
KAKA
