Ball joints
cody mummert
Pa
So I have a squeak on the drivers side when turning and suspension travel and I cant tell if it's the upper or lower ball joints . I do have 2 inch leveling blocks on the front. Any idea which one it could be?
0rion
Ohio
5.9 cummins
Just my opinion but if you tear it down that far do both.
BigRed4x4
Mid Michigan
I agree. However... I had a a terrible squeak like the OP described and only had my lowers replaced and it fixed the problem. I have a bilstien level set at 2.1
R.L.K.
Bristol , Tn.
The level block spacers typically kill the upper ball joints in the UCA .
I installed the Bilstein adjustable shocks about 50,000 miles ago at +2.8" and are really happy with them , if that's not an option for you then you could install Mevotech Upper Control Arms , they are not expensive and have a greasable ball joint and have a good reputation with the Ram trucks with level kits . I've had them on my truck for 50k with no issues [emoji1303]
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
3.92 8 Speed 5.7 4X4
Before you go disassembling or changing control arms, have someone articulate the front end or jump on the running board to pinpoint the noise.
If the spacers are aluminum, tighten the top 3 nuts an extra 10 ft/lbs and throw a shot of water resistant lube down the strut tower.
I'm only running a custom billet 1-1/8" puck to half-level with Mevotechs, but anything over 1.5" puck I'd definitely plan on upgrading the UCAs especially with frequent articulation off-road.
meedom
Hey RLK how often do you think the Mevo's should be greased after the initial greasing on install??
R.L.K.
Bristol , Tn.
I grease mine every oil change so usually about 5-8k ish [emoji16]
meedom
Thank you sir, sounds like I better grab a grease gun :favorites13:
