Battery Charger / Maintainers - 2025
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
I created a new title for battery charger / maintainers, because they are NOT "trickle chargers" as other posts title them. Also, these are general garage items, except for those that mount in their trucks, and apply to any generation of Ram Truck.
Trickle Chargers were only that - 40 years ago. They supplied a constant, low current to a battery regardless of the charge state of the battery. Well, that's not good - you can boil off a conventional lead acid flooded battery's water that way, or start a fire on an AGM or Lithium.
Hence, the "smart" chargers that came out over the past decades. Originally made in USA and Europe, they have ALL been outsourced to cheap Asian nations. Except for the larger units above 10 amps. So, it's important to see which companies are enforcing quality standards on Asian Factories, and which are not. Smart chargers both charge AND maintain batteries, i.e. - they should not overcharge them. They need to detect the battery voltage and apply the proper current for that voltage until fully charged, then leave the battery alone until it needs charging again.
Below is a link to a 2025 test review from Project Farm guy, Todd. With companies constantly moving their product production all around the world, this is a current look into product performance. App. 10 years ago, C-Tek was best, then they moved to China. Looks like NOCO and Battery Tender Brands are better today.
I use the 5 amp nominal chargers. Enjoy!
G/T jonny
California
Hemi eTorque 5.7
I use the battery tender jr. 750 ma. I’m warm weather. In cold weather a stronger one would be more appropriate.
Plug into the 7-way. Definitely leave the 2-pin connection in-line as a “breakaway”.
TradesmanGuy
Marine Corps
PNW
PentaStar V6
I'm all but certain that I have burned up a few batteries. Finally got all the maintainers I need. NOCO 1 and 5 amps, and a 1Amp Battery Tender. In the winter I set'em and forget'em.
BLAK
oregon
I'm a big fan of the NOCO Genius chargers/maintainers. I've used a 10 amp/2 battery maintainer on my boat and the 5 amp on two trucks. I permanently mount them under the hood and run the plug to somewhere accessible. No problems at all.
BlueDwarf
3.0 Twin Turbo
Speaking of battery maintainers / "trickle chargers", on the 2025-2026 3.0 twin turbo SO, should the charger be attached to the main battery or the auxiliary (smaller 2d) battery to keep the charge up for starting. Does it matter which? Haven't been able to find a definite answer.
seems fishy
Ontario
6years ago I bought an Optima battery charger,maintainer.Charges Optima,and ODDESSEY.USED IT ON BOTH.Works on even lawn tractor batteries too,and 12vautomotive wet batteries.Very versitile.I have in on my lawn tractor battery outside all winter
