Tulet
Has anyone else had a problem with the felt battery cover? It seems that an air flow has shredded my battery cover. Not only did it shred the felt, the debris of felt converged around the 2nd cylinder wire lead and frayed it to the point of failure. Have contacted Ram dealer locally and will have an answer tomorrow. Yesterday it started running rough so I ran a diagnostic on it today and found P0032, P0038, P1129, P0301, P0138, and P0152. That's when I pulled the Engine cover and Air Intake hose from the manifold and found the offending felt. Don't know if it can be repaired in place or if the harness needs replacement.
