Trey Sledge
Gonna add bed lights to the truck. Are the factory ones worth the $100 or is it better to go aftermarket?
Damn I like the look of your bed lights.When I went through this same decision, this was my thinking: The factory bed lights sit in the back of the bed and shine toward the cab, if there's anything in your bed blocking that light, you can't see anything past it. So I liked the LED rope bed lights because you get continuous light through the length of the bed. So you have to have a ton of stuff in your bed in order to obstruct that light. So I chose the aftermarket lights mainly for that reason and you get the added bonus of them being 1/3 the cost.
what is that wall on the left side made out of?
Blue Mule
Normally I would say no because I could add my own for less, but they were already on my truck when I got it. That being said, if I were to order a truck, I would spend the $100 for the factory option. They are bright enough, they have a waterproof switch integrated into the side of the bed, they are also controlled by the cargo light switch in the cab.
Very nice add on worth the $100.
Thanks man much appreciatedIt's made of HDPE (High Density Polyethylene)
This thread has all the information you'll want (and probably more) on my bedside rack.
Here's the link:
https://www.ramforum.com/threads/how-to-bedside-utility-racks.128171/
It's on the driver's side, directly under the bed light. When I go out to my truck later, I'll snap a pic and post it hereWait where is the switch on the side of the bed?
Following it now. Awesome buildIt's made of HDPE (High Density Polyethylene)
Here's the link:
You don’t have it. The switch showed up on the 2018s.I’ve owned my truck a little over two years, never noticed. I’ll have to go look! I knew about the switch in the cab.
Where did you get the lights at?
I added the amazon rope lights to mine about 18 months ago. I have mine wired into the OEM bed lights, no codes or bulb out messages whatsoever, easy $20 mod.
