Bed Rail Caps- Bulge in warm weather
BrBlack
Calgary Alberta
Curious if anyone else has seen the plastic box rail caps bulge in the summer heat?
For me both sides are doing this. When the temps climb the plastic sticks up in the middle. Is there anyway to fix this? Or should I just replace the caps on both sides?
5.7cmax
Can you post pictures mine have never done this
BrBlack
BrBlack
Calgary Alberta
Ok snapped some pics last night.
It was much cooler yesterday so the bulge is somewhat minor. In the hot sun the gap can get to be 2-3 times as big.
Not sure if there is a fix or if i just need to replace the plastic?
fire101fighter
South Jersey
I got two new rails from the dealer for $90 total. Easy enough to replace. Was worth it before I put the new tonneau cover on
5.7cmax
That's so weird my guess would be you bed cover pulling on the sides but not sure temperature in the summer are in the 90's and get close to 100 but I don't have a cover and I've never had that problem
5.7cmax
Summers for me^
billyw
Northwest
That happened on my last truck too (F150). I ultimately just learned to live with it. I would opt for new rails now.
ddetta88
SLC, UT
I have been looking for the caps online cause the previous owner drilled holes in them
I guess I need to contact the dealer
BrBlack
BrBlack
Calgary Alberta
Appreciate the replies. I'll likely just have to replace the rails. When they bulge in the heat it just looks ridiculous.
drooler
Alberta, Canada
2015 Sport
I had the same problem. Dealer replaced them last summer under warranty however the new ones are starting to do the same thing. Dealer stated that it's due to the tonneau cover.
BrBlack
BrBlack
Calgary Alberta
Interesting.
My warranty is long gone so its up to me to replace these. Did they happen to say how the tonneau cover did this? I have the Truxedo Low Pro QT cover currently.
Neumie
MN
5.7 8a
Had mine replaced under warranty. Started again, not too bad yet but disappointed nonetheless. Looks like a stiffer plastic would be beneficial.
ddetta88
SLC, UT
I just bought two new oem caps from the dealer 143$
drooler
Alberta, Canada
2015 Sport
Interesting.
Basically the side rails that the cover attaches to puts tension on the rail caps. Like I said, the replacement ones are starting to do the same although after a year they aren't nearly as bad as the original ones over the same time period.
I too looked at the aftermarket ones although couldn't find anything that I liked and certainly didn't want chrome on my Sport. If anyone has seen any in a powdercoat send me a link.
Fryekenn
