Been working with Hemifever for us 2011 guys
TheBlackHemi
I ran baseline runs with the diablo canned 93 tune vs his baseline custom 93 tune last night and I must say if you thought on settling for diablos tunes I would suggest going with Hemifever and get one custom.
Here's his feedback on the the two separate logs canned vs custom....
Being that you did this on two separate days, the numbers will be skew'd a little. But with the can tune it took 7.3 seconds to do 35 to 75 mph and 12 seconds flat to do 35 mph to 90 mph. With my tune, it took 5.9 seconds from 35 to 75 mph and 9.5 seconds from 35 mph to 90 mph.
A HUGE difference but there were different factors. On the RT that I did last night the runs were the same road and back to back. My tune was .6 quicker in 60 to 100 mph
Looking at the two logs though, you should feel a big difference in power and driveability
Last night the log I ended up sending him was on a bumpy uneven road (cops out like crazy last night on my normal run routes) and with my truck running over 45mins looking for spots to run at around in my area not ideal to get a baseline on his custom tune but still showed some good results.
He made some changes to my tune and resent one this morning so I'm sure when I make a couple of runs to day it will even better than the last. Hemifever works quick as long as you get your logs into him (I've working all week during the day and sending him logs at 9-10pm at night) I'm sure he can evaluate it and resend a new tune or two in a day. He also does tuning to the transmission which is a night and day difference compared to stock and even better than diablo's tunes. The up shifting and down shifting is no longer lazy as stock was....it just grabs the gears and goes.
I will update as I get more logs and retunes in but If I had a tuner 09-11 rams I would suggest getting in contact with Hemifever because his custom tunes are tailored made for you vehicle vs one size fits all like the canned diablo tuned offers.
GhostRam94
Hunstville, Texas
2009 Laramie CC
this is awesome, i might need to get with him sooner than later on mine
TheBlackHemi
TheBlackHemi
I just cut a 0-60 in 5.7 secs with his revised tuned he just sent me with 22's....pretty impressive for a CrewCab. Today I'm gonna be swapping out my mopar cai with a vararam intake and swapping my fastman tb (84mm) with ones of Matts (moe's performance) 87mm throttle body.....will report back the results.
UPDATE....
Here are some screen shots from my datalogging.....I started at 25.459 secs and ended at 31.16 secs= 0-60mph in 5.701 secs, Sean from Hemifever is getting this thing moving. Just FYI diablo's baseline ran 6.2 secs and Hemifever's first baseline tune ran a 6.0 flat....now 5.7secs on his first revised tuned, he know's what he's doing for sure.
retiredfireman
Maryland
jebus! will the opportunity to spend cash ever stop... haha
I cannot wait to get the tuning from db and then a custom tune.
TheBlackHemi
TheBlackHemi
No but I think I might just have my truck where I want it....gonna start a project on a mustang 5.0 in the spring/summer.
Another update.....
My fastest 0-60 run of the day was 5.579 secs and same log 0-95 run in 13.415 secs all done in 86 degree weather....I think I easily have 13 sec truck at the track LOL
I just finished installing the Vararam intake (had a mopar cai) and swapped my Fastman TB 84mm with a Moe's Performance 87mm TB. Gonna try to get some logs later on tonight and will report back.
TheBlackHemi
TheBlackHemi
Update once again...
These are my best times yet, I couldn't do a 0-95mph pull for yall truck was moving like a freight train and had to slow down so I wouldn't hit the car in front of me LOL.
Here are the results all pulls are on my 22" wheels...
Pull with Mopar CAI and 84mm Fastman TB
Tune revision from HemiFever (1/4 tank and 86 degrees)
0-60mph in 5.579 secs
35-75mph in 5.448 secs
35-90mph in 9.027 secs
0-90mph in 11.695 secs
Pull with Vararam intake and Moe's Performance 87mm TB
Tune revision from HemiFever with Vararam/87mm (full tank and 74 degrees)
0-60mph in 5.573 secs
35-75mph in 5.445 secs
35-90mph in 8.751 secs
0-90mph in 11.138 secs
I know the Vararam and 87mm TB pull was at 74 degrees but I also had a Full tank of gas vs 1/4 I had it earlier today.....All I can say is wowthe Vararam and 87mm TB start to pull away after 75mph !!
09SMOKINHEMI
TEXAS
The Vavaram and 87TB definitely helped out your top end. good stuff here
paulycoppola5
Schenectady, NY
those are some impressive numbers!!
love to hear about your 5.0 project, my garage had a few run ins with a mustang or two.
TheBlackHemi
TheBlackHemi
Most likely I'm gonna do a centrifugal set up (Paxton) seems to be most bang for the buck (6k with 1000id injectors,CAI, and a BAP) relativity cheap compared to a positive displacement sc (6k just for the kit) and turbo setup (8k).... the kicker with the Paxton kit I can take it to 1000hp (when I decide to make it a purely drag car) and most people are putting down low 600rwhp at 8-10psi with the stock pulley and running mid to high 10s but with a converter low tens in the 1/4. I just saw a twin turbo set up put down high 500s with only 5.5# of boost so I guess when that time comes I'll decide either the Paxton SC or a twin Turbo setup but won't start boosting it hard until I get bottom end forged.
Arturo Rojas
