Bent Exhaust
PopATop512
5.7 Hemi eTorque
My back left bumper recently got hit while it was parked and bent the exhaust towards the middle of the truck. I was able to return it to place and adjust the exhaust tip but the pipe looks a little kinked right behind the resonator. Does this look normal? If not, is this bent enough that it will cause issues down the road?
Ken226
Washington State
Great, thank you!
Inspect the connection between the y-pipe and exhaust manifolds. If there was enough impact energy to bend the pipe, it could have damaged the interface or broken a bolt.
If you have an exhaust leak there, it would probably set codes.
