Best Break In Oil for a 3rd gen rebuild for a 5.7
YapoInvestments
Dallas Tx
2005 Dodge Ram 1500
Hi guys I would like some guidance on which break in oil I should go with. I’m just confused on what brand I should get? My engine takes about 7 quarts. I’m about to put back together after installing these new parts :
Hellcat lifters
Cam
Pushrods
Oil pump
Thermostat
New oil pan
New timing tensor
Just overthinking it because I can’t find any answers on other forms.
pacofortacos
I would use almost any decent brand conventional oil, not a blend, not synthetic.
Those oils you list are for non-roller lifter motors.
Y
YapoInvestments
Dallas Tx
2005 Dodge Ram 1500
What really? ***** I think I just searched best break in oil for my “truck” lmao
so just 5w-30 conventional oil
pacofortacos
Quick question, is it a complete rebuild with new rings or just the listed parts?
IF complete rebuild with piston rings, I would use conventional oil for the first 3000 miles with the first oil change at 300-500 miles.
IF JUST the listed parts, I would go straight to Redline 5-30 as you aren't really doing a breaking, there's no break in on roller cam/lifters.
chopperman1
Peoples Republic of Massachusetts
2018 Rebel
5.7L HEMI
As mentioned in your other posts, you do not use a "break in" oil. There is nothing to break in! Piston rings are the only break in item.
Y
YapoInvestments
Dallas Tx
2005 Dodge Ram 1500
Just the parts listed and the gaskets ofc
Y
YapoInvestments
Dallas Tx
2005 Dodge Ram 1500
Okay I’ll grab the red line 5w -30 conventional oil?
Y
YapoInvestments
Dallas Tx
2005 Dodge Ram 1500
pacofortacos
Hellcat lifters
Cam
Pushrods
Oil pump
Thermostat
New oil pan
New timing tensor
Redline 5-30 is synthetic (as mentioned) and one of the best oils for the 5.7.
It has a really good additive package that the 5.7 hemi seems to really like.
If you don't want to spend the high $$$ on the Redline any quality synthetic oil would work, the 5-30 weight is good for hot climates and/or towing.
Since you just did the cam and lifters you don't need any special break in oil.
So you can just go for the good stuff right from the start :)
Y
YapoInvestments
Dallas Tx
2005 Dodge Ram 1500
Okay I’ll get the good stuff
ManBOOYA
