Best Cam Options for ‘03 5.7 Hemi?
Jrex
Charleston, South Carolina
Trying to find a good horsepower boosting Cam hopefully without replacing too much more of the internals if possible. Would like something with some chop if possible and I’m having trouble finding good info on the topic
GIJoe2010
No sh*t, there I was . . .
Killeen, TX
On my old 08 Charger I had an Inertia cam and it was awesome. If you check out a lot of the LX platform (Charger/Challenger/300) forums there's a bunch of stuff out there. High Horse Performance, Modern Muscle and Arrington all come to mind as well.
chrisp2493
Always Modding
Warren, OH
392 Hemi
With your 03 you’ll be very limited on cams because of the weak tuning ability with the pcm. A comp 260 is about the biggest you can run and you’ll need custom tuning to deal with it. But it doesn’t have very much sound, it’s barely noticeable. I clean that cam for a few months. Your best option is doing some electrical work and changing to an 05 pcm. It’s not a lot of work if you can read a diagram and solder some wires, quite a few people have done this now and I have a lot of info to help you through it. But it’s almost a necessity to run a decent cam. Other thing is you need to upgrade the valve springs and pushrods. 6.1 Hemi exhaust springs and 6.1 Hemi pushrods work great, I’m using them with my stroker and a .556/.561 lift cam
I Bleed Ram Trucks
Jrex
Jrex
I Bleed Ram Trucks
Why specifically an ‘05 pcm?
chrisp2493
Always Modding
Warren, OH
392 Hemi
The 03 and early 04 pcm’s have 2 different modules. One is the PCM and the other is the Transmission Control Module (TCM). They have very limited tuning abilities, and the transmissions can’t be tuned. The 03 can’t have the idle rpm’s changed, which is crucial for running a cam, most need the idle bumped up 100-150 rpms to idle correctly. The 05 is the best all around year to use. In late 04 they combined the PCM and the TCM into the same computer, but still have some issues with transmission tuning. So what needs done is taking about 28 wires from the old TCM connector and wiring them into the PCM connector. It’s sounds intimidating but it’s not really. I have a very straightforward instruction thread typed up to help out. Also the 03 truck will have only 2 oxygen sensors, the 04+ trucks use 4, so two sensors do need to be added to the exhaust and wired in.
I Bleed Ram Trucks
mwclarksr
Mooresville, Indiana
4.7L - 287cid
I Bleed Ram Trucks
Never mind I'm reading your thread about the subject now
HemiLonestar
Navy Badge Coast Guard
MD
Chris is spot on... if you want to modify/re-cam a 03 the first thing on your list should be to update to the 05 pcm.
Totally off topic, but hey Greg guess what I found in my garage lol?
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
No idea, what did you find?
