Best headers for 2013 5.7
Chris02
Fort worth
Hey there chat, I got a 2wd 2013 ram 1500 single cab express model. As expected I am ticking, ram life is pretty nice up until you hit that 110k-115k miles. I’m fairly sure it’s my header bolts, my heat shield on passenger side had 2 broken bolts so I can only assume most or all of the bolts on the header are ******. Like any normal ram guy the only right thing to do is go ahead and slap on some long tube headers. now heres the question what headers should I go with, why are some headers absurdly more than others, what’s the difference between 1 3/4 and 1 7/8s, and what’s the best header for me as my first engine mod with ability to do more upgrades later on like 6.4 intake, hellcat lifters, cam, upgraded oil and fuel pump just a rowdy daily truck not trying to be the absolute fastest just trying to sound and look nice
EdGs
FL
As far as your exhaust manifold bolts go, if you belt-sand or have the manifolds machined flat, and replace the hardware, and you'll never have another issue.
Does your tick happen when cold and subside after it warms up? Sometimes those stock exhaust manifolds can warp so much that the tick does not go away when warm.
If you want to go the header route, others here will chime in on that. Good ones ain't cheap, for sure.
Good luck, enjoy your Ram.
CanuckRam1313
Ontario Canada
2023 Warlock
If going with LT's, here's some info to help you decide on sizing:
Personally, if staying NA engine and not going too crazy with the mods, I'd go 1 3/4, but that's me.
If you opt for LT's go for good quality and stay away from the likes of BBK and brands like them.
Buy once and cry once, then enjoy the experience of improved flow and performance.
@Nick@GotExhaust is a trusted site supporter and vendor and has a wealth of knowledge to help you select the right LT's with new gaskets and hardware.
If you're going to stay with stock manifolds I'd be looking at BD Diesel manifolds with new gaskets and hardware.
These manifolds are an improved design to the OEM stock ones and won't warp down the road.
Mojo88
Rhode Island
'19 Longhorn Gen5 ORG
Hemi 5.7L non-eTorque
Unless you're going to do forced induction of some sort, I would do 1 3/4" headers. Additionally, since you want a nice sound, I would be sure to get equal-length (sometimes referred to as 'tuned') headers. Using tuned headers with an x-pipe and dual exhaust produces the sweetest exhaust note ever IMHO.
Daw14
South Florida
I have 1 3/4 “ ARH Longtubes , with the 6.4 intake and 6.4 injectors.
Be prepared for broken bolts.
Also installed a tru-trac with 4.56 gears .Due to the six speed.
I would keep the 1 3/4 “ unless planning on power adders.
Adamcr68
Lorton VA
Hemifever 5.7
I’ve been happy with my Stainless Works long tubes, I had them installed for 2-3 years with no issues yet.
They aren’t cheap, I have seen other members that have had success with cheaper ones, probably “middle of the pack brands” not the cheapest one you can find.
Fitment issues & weld quality seem like the biggest problems with less expensive options IMO.
Check out Ebay headers,as the name brand headers are stupidly priced and aren't really much better then what you can buy off ebay.No way in hell should a set of headers cost $2500+.
Ken226
Washington State
This is an interesting manifold design:
CanuckRam1313
Ontario Canada
2023 Warlock
Quite similar to the BD Diesel design except these are in SS.
Interesting indeed!
16WhiteQC
Hudson valley, NY
1 3/4" for a street truck vs drag truck.
LT's are a PITA to install, especially on a 4wd.
You will have broken bolts to remove from the manifolds, make sure you have a welder ready
The factory dipstick sucks if you plant to weave it through the primary's
I went with high flow cats and still ended up with rear 02 efficiency codes.
I love the power/TQ gain...BUT in hindsight I might have been better off with BD manifolds or good shorties.
Adamcr68
Lorton VA
Hemifever 5.7
Didn't see anyone mention that going to long tubes, will mean installing a tuner and getting a tune, also.
Just another cost that needs to be added into the equation.
Good point! I do have a tune but believe I’ve read that you could add long tubes without issues, get the tune later, you won’t get the benefits without the tune.
YetAnotherUser
