chadster21
- Jun 22, 2012
- 119
- 15
- 2017
- 6.7 cummins
ya right on, i have a 6'' aswell i found it quite a bit rougher, not sure if its the lift or the tires thats giving it the stiffer ride
Im wrong? Ok whatever. Ive had leveling kits on all types of trucks and every leveling kit that were spacers made my trucks ride stiffer. Do what you guys want to your trucks and I guess dont listen to my two cents because im WRONG. lmao
a 2-2.5 level with a 1.25 body lift would run you less than $200 for parts. Not bad, and a hell of a change!
You will lose ride quality with spacers. Do bilstein 5100 leveling struts and set them at 2.1" and then get you a 1.25" rcx body lift. This will run you about 320.00 for everything.
Dont set your bilsteins at max settings you will be sorry. You will get vibrations in 4wheel drive. It.only works if you have a drop mount kit. Like a 4 or 6" lift. Just helping you out bro.
i dont think a 12.4'' wide tire is gunna fit with 0 offset
Really?
Based on this calculation it says it will....but it maybe in accurate or not.
Tire/Rim Calculator
Based on 275/60/20x9, +18 offset (stock): 315/60/20 tires (with the 20x9,0 offset) will be 2mm closer to suspension, it will stick out 38mm (1.5") from the fenders and fill the wheel well by 24mm
If our stock offset is +19 vs the +18 (not sure what it is as members say either or)
It will sit the same as stock (because of the 0 offset)
Now the 295/60/20 Terra's are actually larger than most this size too at 34.5 (H) x 12.4 (W) and members have been able to fit this with just a Bilstein level and nothing more.
This will sit worst case 2mm (0.1") closer to suspension over stock
So not sure what to believe here. This also does not factor a level or lift.
I know you have a lift at 6" and I think a -12 offset? Which means it sits further out from your fender. But for sure -12 clears.
The wheels I want only come in a 0 offset.
Pls correct me if I am wrong....
12.4" tire will fit with no problems on a 20x9 wheel with 0 offset. Now you will need at least the level for the 34.5" or 35" tall tire
Thanks for the confirmation.
I love your setup
Based on my above...what are you thoughts?
(Re cap, Bilstein 5100's, 1" rear coil spacer and 1.25" Body lift. I was hoping to set the Bilstein at 2.8 but as Big Horn 4 Life mentioned some have that vibration/wobble which I absolutely dont want.
I do have a 2012 Sport and dont have AWD, rather 2wd, 4wd lock, 4wd lo and 4wd hi)
Thanks
are you going for a leveled look or a lifted look with still having a slight rake? If you want leveled i would not put a 1" coil spacer in the rear.
i honestly dont' think that will lessen your chances for the vibrations....its not the form or brand of level that causes it, its that fact that when you level you are increasing the CV angles.
Its a hit and miss. Try them at 2.8" and if it doesnt vibrate then leavem. If it does vibrate the lower them to 2.1". I wouldnt put spacers in the rear of you want some rake with them set at 2.1".
Yes there is a stock setting on the bilsteins. You should not get "any vibrations" at 2.1".
The 2.1" setting is the second one from the top. You might not have waisted money on the coil spacer. Try the 2.8" setting and see what happens.
If your going to put a 6" lift on.it why dont you wait and do everything at once. Cv's are high dollor.
