Best Mods for under $100 (5th Gen Edition)
Hawkman
South Carolina
MileHighRam11
Colorado
The journey to black out another truck begins…$48 for Raxiom smoked third brake light. Plenty bright even during the day.
Bravo619
Tulsa,Ok
Hemi 5.7 gas
How bout the pesky groan coming from the back brakes when backing cold! The best money I ever spent on a vehicle! IMG_8539.jpeg
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
How bout the pesky groan coming from the back brakes when backing cold! The best money I ever spent on a vehicle! View attachment 569506
Thanks for sharing this as I wasn't aware it existed for this issue that I also have occasionally on my 22 1500 (Not sure if it applies to 2022 DT's?)
>> Did it help with the noise while reversing? (vs placebo) <<
Additional links:
Moan Brake Kit - Mopar (68446866AA)
Amazon Link
RamForum: Brake noise when backing up - 2019 1500 DT
RAM TSB 05-002-19​
Make:RAM
Number: 05-002-19
Title: Rear Brake (Moan) Noise
Date: 4/25/2019
Summary:
The customer may comment on the following: A low frequency moan or howl noise from the rear brakes, primarily in cold/humid conditions, typically on the first brake stop in forward or reverse, after vehicle has been sitting for lengthy periods of time (cold brakes). This bulletin involves installing a rear brake anti-moan kit.
sdeeter19555
Reading, PA
1990 and 2019
So I found these Superspring clones for $70:
They came without directions, unmarked box. They are, as far as I can tell, identical to Superspring. If I didnt know better, I'd say they are a factory seconds. Powder coating is nice, hardware is good, fit is perfect. Again, comparing these to pictures of Supersprings, hard to see any difference at all right down to the pattern on the bottom. They are fairly simple to install (using Superspring instructions), couple of the bolts took a stubby wrench and a ratcheting wrench is all but necessary.
Had them for about 150 miles, not too bad on ride...I did NOT install the spacer as they touch the axle without them (would have been pretty harsh). I didnt need much extra support, mostly for those overpacked long duration trips where you're just "heavy".
I had airbags (coil inserts) but they were "odd" to say the least, definitely nothing like a traditional airbags. So those will be coming out at some point.
On edit: 2019, 5th gen 1500, with coils...perfect fit.
smoke8r
kingston, ON
2020 1500 sport crew cab blackout package
I installed a Rear camera washer and reverse pod lights last weekend. Make a huge difference and is one of those, why did t I do it sooner moments.
Rear camera washer:
Attached 2 pod lights into my trailer hitch and tied them into the reverse wires of the trailer hitch.
FerrisB
IL
Stake pocket covers - great if you have a cover and help keep water from leaking down through the plastic bedlight covers (if you don't have the lights), which I had to silicone in after the bed was sprayed.
Overkill after the silicone fix? Probably. But, made me feel better.
https://www.amazon.com/gp/product/B0026Y3YGK/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
I got these ones
BHpgh
