Lol yea I thought it dressed up nicely. Just took the orbital sander to it to smooth out the fuse symbol, painted, put the decal on, and clear coated over it.I've got some plans for that now.
What relocation kit did ya go with?Oil filter relocation and ez drain valve. Total $89.90 $53 for the kit, $24 for valve, $12.50 for filter, hose clamps and thread seal.
Looks good!!!!
I like the oil filter relocation but why didn’t you make changing it easier by mounting with the filter UP so oil drains out upon shutting off the engine/opening the drain valve?Oil filter relocation and ez drain valve. Total $89.90 $53 for the kit, $24 for valve, $12.50 for filter, hose clamps and thread seal.
Also, you’ll find the a nopales on the drain valve goes a long way to avoid drips. Install a nipple then when draining simply place a plastic tube on the nipple and drain into a container. No drips. Easy Peary!
That looks awesome. Where’d you find that?$49 for LED tailgate light bar on my RTT frame
Good deal bud! ThanksThank you! Amazon. Here you go!
49" LED Tailgate Light Bar for... https://www.amazon.com/dp/B07YNZ5XHX?ref=ppx_pop_mob_ap_share
Sure, it also helps with bayonetting and butt-stroking...What is your reason for grip tape on your rifle? Wet weather hunting?
Did the same thingInstalled some tie hooks by erickson. Pretty well priced, $20/2 CAD at crappytire. Pretty easy install, just requires a philips and a sharp utility knife.
Bought this for another project and decided to use it in the door sills since I had a lot left over (still do too)...
https://www.amazon.com/dp/B00RU8FEWO?ref=ppx_pop_mob_ap_share
On truck...
Original project...
Worked great for both projects. I hit it with a heat gun after application to help the glue out.
