Biggest tire on stock height
Fredo
New York
Does anybody know what is the biggest tire I can put on a 2017 ram 1500 sport with no leveling kit just stick height. I have 275 60 r 20 right now what kind of offset dont want the tires sticking out
Lifted2wd
are you running factory wheels or aftermarket? You can run a 34" on factory height.
LVnight1500
305/55R20 if you want wider while only going a fraction higher.
jdavila99999
The stock tires are 33”
Rims 20x9
0 offset
jdavila99999
Stock rims 6c2e983164805d3b3c8a7a06030644ff.jpg8ec11d8045a99ac3d20776125e92c4e9.jpg
EagleChief
Oklahoma
2014 Big Horn
You can run a 34" or even a 35" tire with a leveled truck. With 35's, you'll have to run spacers to push them out a tad so you don't rub... at least from what I've read on here... don't take that as gospel.
It seems as each truck is different. You can have 2 different trucks with the same tires/wheels/setup, and 1 will rub and the other will not.
I'm leveled with Bilstein's up front and my next set of tires will be 34".
LVnight1500
I believe the newer stock wheels are 20x8 with 19mm offset
Jeffmiller32
I’m running 295/60/20 Cooper STT on fuels. Stock height. Actually thinking of dropping the rear 2”.
jdavila99999
New stocks are 6 lug
Lifted2wd
My 2015 stocks are 20x8. It's all about offset. I have a 37 on a 4" lift stock wheels. You can run close a tall tire around 34 to 34.5 stock height. Each truck is different, what fits on one might rub a little on yours.
ram1500rsm
Trabuco Canyon, CA
My friend has 285/65/20 BFG KO2's on factory wheels, factory suspension. Fit without any rubbing, he's got a 2013 RAM 1500 crew cab.
boblonben
You are correct!!! In fact anything with stock wheels are 19MM offset since 2002. Before that - old body style, one got either 0 offset of -5mm offset with the off-road wheels.
Big Blue Hemi
Keep on keeping on
Right Coast
2012 Ram 1500 Laramie
This offset issue has caused confusion to me and others I am sure. I have been informed that less offset than +19 pulls the wheel out BUT others have said the opposite. Which is which?
Triumphx
The higher the offset the wheel will be tucked more. The lower offset the wheel will poke out more.
Steve Holtz
