Billet Catch Can mounting
URdone21
CA
2013 Quad Cab
So I'm about to get a Billet Tech Catch Can. I read somewhere that having the can mounted with the Z bracket has the can sitting too low, causing the can to not perform as efficiently as it should. This is as opposed to the fender mounted option where it is higher up. What are your guys thoughts on this? Is fender mounted even an option for my 2013? Thanks
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Nobody makes a fender mount for the Ram trucks. The Z bracket included with the Billet Tech kit is perfect. It works flawlessly.
URdone21
URdone21
CA
2013 Quad Cab
Good news. Thanks guys
audio1der
Airdrie, Alberta
A #-4" piece of flat stock bent at 90* with three holes drilled will aloow you to bolt it to the back of the rad. If you get imaginative there are numerous options.
Mine is higher than the BT can mounts but I have yet to drain ut until I change the oil in the next couple of nights. Duh duh duh!:popcorn:
Cynix
Edmonton
2013 Ram 1500 Sport
Mine seems to be working on my 13'
After about 3000 kms I'd say it's doing well
URdone21
URdone21
CA
2013 Quad Cab
One of the benefits listed for this product is increase in fuel economy. Have you noticed that at all?
Cynix
Edmonton
2013 Ram 1500 Sport
Well I can't attribute one thing to increased economy but since I've done my Vararam, ported tb, exhaust and the catch can I'm getting about 6L/100km better on average... This of course is along side breaking in the truck and better fuels cause of summer
Gunz86
I think I would be afraid of my can sitting any higher, hitting a speed bump or any hard turns letting oil down the wrong tube and into the into chamber vs letting gravity work the oil back down into the can.
URdone21
URdone21
CA
2013 Quad Cab
Got my can installed yesterday. Install went smoothly. About how many miles before I will see something at the bottom?
limited
2012 Black Limited 1500
I checked mine for the frist time at 2500 and the can was 3/4 full, seems like alot.
I change the oil every 5,000 on amsoil, 17,000 on truck
Gunz86
Checked mine within the first 100 miles and had oil in mine, can works great.
audio1der
Airdrie, Alberta
I checked mine 3,100km after installing it, during my routine oil change.
I have 3' of hose off the bottom of the can to a 2nd ball valve so there is more lining the sides etc, and I still collected this; between 1/4 and 1/3 cup. Yuck!
TRXHemi
Sugar Land, TX
So this goes in between the breather hose that goes from the top of the intake to the air filter housing?
tkyle486
I checked my around 100 miles and had stuff at the bottom. this is a must Have whether your going to mod out ur engine or wanting to extend the life of if.
Casper
U.S. Navy (Ret.)
Springfield, VA
5.7L
Not quite. PCV on back of the engine passenger side to just below throttle body.
apepe0738
Peoria, Arizona
2012 Ram 2500 Crew Cab 4x4
I did, after I installed mine I get on average 1-2 MPG more than I used too... Truck seems to run a little better but that could be just me...
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Like casper said, it replaces the PCV line on the passenger side of the motor that goes from the back of the intake manifold to just under the throttle body. The Billet Tech kit comes with a Ram specific mounting bracket and bolt that will mount to an existing drilled and tapped hold that is already on the front passenger side of your engine block.
TRXHemi
Sugar Land, TX
Thanks guys.... for some reason, I was experiencing a brain fart.
