Bilstein 5100 Adjustable Front Leveling Question
jlasorsa11
HEMI 5.7
(DISCLAIMER: I already searched for this, no answers)
I have a 2012 Outdoorsman, plan on installing the adjustable 5100 at the max (2.8) and my question is this - will this level the truck or will I need a rear spacer (3/4 or 1")?
As I measure ground to highest point and center of the wheel wells, this should still leave a 1/4 inch of rear height, which I would prefer.
Has anyone applied the 5100 at max on an '11 or '12 outdoorsman?
Or even at 1.4 or 2.1 for comparison. Thanks in advance.
quietpeen
2021 TRX
Hellcat
There is a chance you might be nose high at first but as things settle the front will drop a tad
shipmasta
Santa Cruz, Ca
6.7l
I was level as far as my eyes could tell after setting them to 2.8. I have a 2011 outdoorsmen. It has settled some now and I am slightly nose down again.
J
jlasorsa11
HEMI 5.7
Thanks for the reply fellas.
Put them in this morning at 2.75, and had the alignment done. No wobble or vibrations at 4wd up to 35mph, 2wd up to 75mph.
Ground height at wells Before: F 36.5 - R 39.5
Ground height at wells After: F 38.25 - R 39.5
So being set at 2.75" gave my 2012 Outdoorsman a 1.75" nose lift.
I am very happy with this, it looks just a little nose down, which is what I was hoping for because I like a tiny bit of rake, visually and for highway speed stability.
Thanks again for the help guys.
srqFF
Sarasota FL
I wish they would make a 2WD compatible version already. :mad:
J
jlasorsa11
HEMI 5.7
Thanks, yeah your read my mind brother, I have these on order. Can't freakin wait
Thor09
Northern PA
Wow, your dimensions are nearly identical to mine! I just leveled mine with Bilsteins maxed and I was 36.5" front, 39.5" rear. I'm now 38.5" front, 39.5" rear.....I was surprised that it didn't completely level the truck considering we started with a 3" rake and now have a 1" rake. I think both of our trucks look much better tho!!!
Here's a pic with my Bilsteins maxed
bussman180sx
Are you able to install the spring and cap on the strut yourself, or did you have to take it someplace a spring compressor was available?
Also, would it be better to get the 5100 over a leveling kit? HBS is the one I was looking at. What are the advantages of the 5100?
Thanks in advance.
J
jlasorsa11
HEMI 5.7
You'll need a spring conpressor as this install requires disassembly of the strut, not just a spacer on top of it.
Highly recommend these over a spacer kit.
And FYI, the tire shop up the road had it done in two hours, with an alignment for $125
Catchin Zs
Wilmington, NC
Question, do the 06-08 Bilsteins, as well as the ones compatible for 4th gens, have 4 notches on the strut body? Or is it 5?
bussman180sx
Power247
High Point, NC
6.4 HEMI
Seriously!?! Where do you live??? My local tire shop just quoted me $350 to install the front spacers on my '09 :banghead:
Bigdaddy
2022 3500 Laramie CCLB
6.7L Diesel Cummins
Nice so how do you adjust the hight?
fastNugly
Toronto, ON
2012 Dodge Ram Sport CC
Nice level!
Its crazy how all you got was 1.75" when it should have been closer to 2.75"
Any idea why?
None the less....being closer to level looks better than 3" of rake ;)
JJP71584
Pgh, PA
A level completely changes the looks of these trucks...nice work man, sharp rig!
bussman180sx
Will installing the 5100, or any lift kit for that matter affect the factory warranty in any way?
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
The 06-08 Bilsteins have 4 settings...(0", 0.67", 1.34", and 2")
The 09-up Bilstiens have 5 settings...(0", 0.7", 1.4", 2.1" and 2.8")
Fpye
