Bilstein 5100 Adjustable Front Leveling Question
usmfan789
jacksonville, NC
Will installing the 5100, or any lift kit for that matter affect the factory warranty in any way?
i've been looking into the 5100s for awhile i called up the ram dealer just to make sure it wouldnt void the warranty and it doesnt now a full lift kit i would check with the service department of a local dealer to find out
J
jlasorsa11
HEMI 5.7
@ Power247: that's crazy, especially since spacers are much easier to install as to do not require disassembly of the strut...
J
jlasorsa11
HEMI 5.7
I also put on the black running boards that came in today.
Love the way it looks.
J
jlasorsa11
HEMI 5.7
They were 160$ shipped off of ebay, so I bet if you really wanted to you could sell yours and get a set of black ones for nothing or for at least a lot cheaper than dipping yours.
fastNugly
Toronto, ON
2012 Dodge Ram Sport CC
Very true!
I will take a look on ebay
Power247
High Point, NC
6.4 HEMI
I know right?!?! Luckily I found an old friend that I used to work with that rebuilds Toyotas. We are going to do a little labor trading. I am going to help him do his current project truck and he is going to help me with mine. Just waiting for it to cool down a little first since neither of us has enough room I our shops to pull the trucks into. Now I just have to decide between the spacers and the 5100's. :naughty:
J
jlasorsa11
HEMI 5.7
Take a look here,
http://www.bilsteinus.com/fileadmin/user_upload/user_upload_us/pdfs/Bil_LevShks_WebArticle.pdf
And here as well.
ORW Bilstein 5100 Ride Height Adjustable - YouTube
Best if luck to ya, either way you go.
fastNugly
Toronto, ON
I'd do 5100's :)
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Definately go with the 5100's. Spacers are exactly what they say they are. The Bilstein shock is a performance shock that is going to give you the lift you need. In the end, buying spacers first and then adding better shocks later is going to cost you more than just going with the Bilstiens from the start.
Bigdaddy
2022 3500 Laramie CCLB
6.7L Diesel Cummins
Yep! what moe's said I just order mines and will probably get the rear later.
fastNugly
Toronto, ON
Exactly what he said :)
daninfamous
Bradley, il
Will using the 5100's to level(ish) my truck have any negative effects on any of my 4x4 drive train?
fastNugly
Toronto, ON
Don't want to say no as some have experienced vibration due to the CV's angled more than they should.
But more members than not have not experienced any changes.
2.1 seems to be the best best for setting to avoid the vibration if it so happens, but again, many run at the 2.8 without issue.
