Bilstein 5100 help
Gioguy9
V6 3.6L
I want to install the bilstein 5100's to get a small lift on my 2016 ram 1500. Do you guys have any other mod suggestions so I could try and avoid any problems with my UCAs/ball joints. Thanks guys
G
Gioguy9
V6 3.6L
No body lift. And yeah it is a 4x4
Scgirardi
Just set at 2.1" and should have no issues
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
Bilstein 5100's shouldn't give you any issues with the ball joints as they keep the suspension travel within OEM specs. If you really want to error on the site of caution you can install a set of Zone UCA's to ensure you won't have any issues but they aren't really necessary for your application.
Mviohl311
Bilsteins set at 2.8 with mevotech UCA's and 35/12.5r20 toyo m/t's on for over a year and never had an issue
LVnight1500
Sweet truck! How wide are those rims? I got the night edition, that came with 20x8 rims. I wish they were 20x9 instead, so I could run 295's.
quietpeen
2021 TRX
Hellcat
are you sure they are 20x8? the night edition is a sport, and sport rims generally have always been 20x9
but i'm sure you will find that many people have run 295's or even wider on 8" rims
LVnight1500
are you sure they are 20x9? the night edition is a sport, and sport rims generally have always been 20x9
on the sticker, it did say 20x8 under standard equipment, but under optional it said 20x8. so i assumed it's 20x8. it has 275/60 tires on it now. do you think 295/60 would fit? i'm trying to find pics of our truck with 295/60 tires with the rims that come with the night edition, and bilstein 2.1 leveling kit installed.
quietpeen
2021 TRX
Hellcat
yes they should, but look at the tires manufactures website. It will list the approved rim width. For instance I have Toyo M/T's in 295/60/20 and the approved range is 8" to 10"
