Bilstein 6112
hodge-xj
5.9 cummins
So would 600lb coils be fine and not make the ride harsher? I really only want 2.5 inches from the strut anyways as I’ll keep my 1/2” spacer on top to give me a bit more lift without maxing out the struts. The only issue now is finding a replacement spring that will sit on the struts properly. And does anyone know compressed and extended lengths on the 6112 vs the 5100 or stock. I read them somewhere at some point but cannot remember where I saw the specs.
If anything 600lb springs will feel better. First they will properly support the weight added, at least better than the stock rate. Second you won't blow through the travel as easily, and third rebound energy stored will be less. All of this will definitely help you in the ride department. Like I said previously, my icons ride really nice and they notoriously have stiffer coils. As soon as I started cranking on them I could feel the difference enough it wasn't worth it without adding weight.
Sent from my SM-N920V using Tapatalk
crazykid1994
crazykid1994
Damn so then maybe I’ll contact eibach about getting springs. I’m pretty sure they make the 6112 springs anyways
