Black Tips
chiefman
5.7L
I am about to order a spinach 6000 muffler and would like some black tips for my 14 sport. Anyone have any recommendations? Thanks
WadXpress
HEMI
Find a tip you like or even your factory tips and either powder coat or scuff up and high temp paint them
I think carven has black tips also
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
Yup, pull factory ones off, scuff them, and paint 3-4 coats of hightemp black. Done.
Moss
Barrie, ON
MBRP makes some and so does Metal Mulisha and a couple others but they are on the costly side of things...
Sent from my SM-G920W8 using Tapatalk
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Are you wanting to go with a larger 5" tip, or stick with a stock size 4" tip?
If you want a 5", then ours are the only bolt on 5" tips. They are also 12" long, so they don't have any awkward step downs visible form the side like the shorter 6" long tips have. We only offer them in polished stainless though, so you would need to paint/powdercoat them if you want the black appearance.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
These are the ones I'm going to run.. Black resonated tips for under $20 a piece and they can be welded on pretty easily..DC Sports EX-1011B Black Stainless Steel Bolt-On Exhaust Tip https://www.amazon.com/dp/B00GMNL36E/ref=cm_sw_r_awd_xhZMvbGAZJHRA
You would be better off painting your stock tips. The ones you linked have an inlet diameter that is .5" bigger than stock (so it wont likely be a bolt on tip), and the outlet is actually smaller than stock at 3.75" (stock outlet is 4").
