Blacked out grille inserts and emblems
Nado
Nashville
Not sure why I waited so long to plastidip these. Pretty simple to do. 3 to 4 coats. I liked the way this turned out. Definitely cheaper then buying a new grill. Might even keep this grill for alot longer now.
Joe_Clark
Kingsbury, TX
How did you prep the plastic? That is my biggest concern with painting or even Plasti dipping the plastic
sent from a device using an app
N
Nado
Nashville
So I cleaned it with a degreaser that I use on the engine. Then made sure it was dry. No issues with it sticking whatsoever. Just need to put on 3-4 even coats. If you take the grill off the car and remove the horizontal chrome slats, hang them when you paint. You will get a better spray when the can is vertical. The emblems were easy enough to just tape off and paint while on the car. Took me all of an hour to tape them, put on a coat, wait 20 mins in between, and put on another coat.
rule18
Admin
NY
2017 Rebel
Looks good...
Joe_Clark
Kingsbury, TX
That is kind of what I was thinking. Thanks
Potatomafia
Tampastan, FL
5.7L
That looks really good with the matte finish of the emblems and grille contrasting against the gloss of the truck.
I went with the Mopar black emblems on my 2015. They are a different shade of black than my truck and it annoys me. Its close enough to where they don't stand out like the chrome emblems but they don't match exactly. Damn OCD. Plus they were expensive for what they are.
Since I have an Express, it has the black honeycomb (Sport) grille. I like the style of the horizontal bars but not the chrome. Yours looks great!
pacofortacos
Plastidip didn't last on my grille when I did it.
Same with the antenna which I need to pull off clean and reapply or paint.
grinder1
CA
Lil secret..... ford f150 antenna is already black and threads in...
Gary2
S Jersey
This will help some of us sport owners get a black grille if what I have read is true . What I read was if you have the shutters behind the grille as I do that the black honeycomb type of grille can't be used without removing the shutters. True or false I can't say . It was not important enough for me to investigate further
Reticle918
