Brake caliper torque specs
Jalisco Ram
California
Does anyone have the torque specs for the caliper, caliper mount bracket, upper control arm ball joint as well as the mounting bolts, lower strut mount bolt ?
13ram1500crew
Ontario
HEMI
This is what i could pull up..
The M21 caliper bolts to the knuckle are 187Nm or 137ft/lbs.
Front caliper pin bolt to caliper bracket are 36Nm or 26ft/lbs
Upper control arm ball joint nut is 180Nm or 132ft/lbs.
Upper control arm to frame is 161Nm or 118ft/lbs
