Broken vapor canister lines
Pruppert04
Illinois
my fuel tank straps failed and the tank fell off the other day while driving. I got it back up and strapped but now the truck sounds like it’s sucking in a ton of air when accelerating. Here are some picture of the broken piece. Any help on where I can find a replacement or cheap fix or even what the hell that hose is called! Thanks!!573A1032-EC60-4D5E-8242-7B015CE87340.jpeg
jws123
nj
Not sure what im looking atdue to the picture but if what i circled in red is your fuel tank it needs to be replaced. As far as the line it looks like it snapped off fitting on top of the tank you will most likely need to drop tank to fix it.
P
Pruppert04
Illinois
Yeah I’m waiting on new tank from lkq that’s epoxy as a bandaid in the meantime. The tee fitting broke. I just can’t find the right verbiage to find a replacement
jws123
nj
It is either a EVAP line or a fuel return line.
