Buying used rims and tires.
Cecil_
I live in west virginia
2011 SLT
Hi I'm wanting to upgrade my stock 17" to factory chrome 20" wheels. Is there any concern with putting bigger wheels on a truck that always had 17" they are factory 20" though. Any strain on transmission
Also the wheels have about half tread left any issues with that
Also they should have the tpms system will that work right away with my factory tpms?
michaelrc51
NJ
Its really about the overall height. That is where your speedo calibration will come into play as well as any other affect on the drivetrain.
To get the TPMS sensors to work on the new wheels you will have to have someone program them in.
MarshRam
2014 SLT 4x4, 2012 ST
As far as the tread depth. Make sure there is even wear. A good sign someone was taking care of them. Get a cheap $3 depth gauge at an auto parts store and measure each of them to verify. Figure out what depth they come in new. Ask the guy how many miles he has put on them. Lastly, subtract 2/32nds from your measurement to figure out how much you really have left.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
You should post up in the want to buy/trade of this forum. Sometimes someone is looking to go the other way.
Cecil_
Cecil_
2011 SLT
I'm not looking to make the truck taller with the 20" the sidewalk size should get smaller right? As long as the two tires heights are the same I should be good?
huntergreen
Marine Corps Navy Badge
yes you should be good as you are not changing the diameter.
quietpeen
2021 TRX
Hellcat
the stock 20's come with 33" tires, the stock 17's come with shorter tires....Your speedo will be off, but it will not strain your transmission. As long as the tpms sensors are from compatible years you don't have to do anything except drive the truck with them on for a few miles for them to register. If they are not compatible you will have to put compatible sensors in the new wheels or just deal with the light on the dash
michaelrc51
NJ
Hmmm. Didn't happen with mine. Now I have to enter the numbers on each tpms sensor in whenever I take the tires off. I'll be dealing with the light for a while I guess[emoji4]
Cecil_
Cecil_
2011 SLT
What to I need to know about buying used wheels with tires.
The wheels are 5 kug and have about 1/2 tread on them. Would I have to get them balanced? Also any other thoughts people have.
CrispyBacon
Check them for damage, make sure the rims aren't bent or twisted.... Take them to a shop if the buyer will let you.
BAMF
Southern Louisiana
2015 Big Horn
Look at the date they were manufactured.... It's 3 or 4 numers with an oval around it normally, first 2 digits is the year followed by the week. I wouldn't buy them if they are older than 4 years old
Sent from my SM-N910V using Tapatalk
Skubasteve!
Also, I believe certain TPMS only work with certain years? That's whats been preventing me from getting certain used wheels. I dont want it to screw that up.
Fryekenn
