C0051-28
louis whiteside
ms.
Ok so I have a 2015 express with 5.7 and 102k miles truck has always run well but I'm getting a c0051-28 code have looked with the scanner and all can anyone break this code down to what is actually wrong
RamRod37
2014 Ram 2500 HD 5.7 Hemi
Georgetown TN
Make:RAMCode:C0051-28Definition:Steering Wheel Position Sensor - Signal Bias Level Out Of Range / Zero Adjustment FailureDescription:Anti-lock Brake System (ABS) Module detects the Steering Angle Sensor (SAS) signal is above than ±15° of 0° while driving straight.Cause:
  • STEERING WHEEL ALIGNMENT
  • STEERING COLUMN OR INTERMEDIATE SHAFT IMPROPERLY INSTALLED OR DAMAGED
  • STEERING ANGLE SENSOR (SAS) LOOSE
  • STEERING COLUMN CONTROL MODULE (SCCM)
  • ANTI-LOCK BRAKE SYSTEM (ABS) MODULE
Failure Type:Signal Bias Level Out of Range / Zero Adjustment FailureThis sub type is used for failures where the control module applies a bias voltage or a zero signal level to a circuit upon which is superimposed a signal voltage (e.g., bias voltage to an Oxygen Sensor circuit, or a filtered digital m/sec2 signal while vehicle stands still for a lateral accelerator sensor module.)
PoMansRam
East Aurora NY
Assuming the steering angle sensor is associated with the clock spring, I wonder if they removed and repositioned the steering wheel after the alignment and messed something up.
L
louis whiteside
ms.
That's what I was thinking I work offshore and my wife took it for the alignment she said they didn't do it complete because a tire was seperated,separated, came home 3 weeks later the light came in truck wasn't driven because she was afraid of the bad tire
