CAI and check engine light
Rampitt
Yesterday I changed my cold air intake replaced it with the Airaid I have it with the stock Airbox. as I was driving to work I saw the check engine light on. when I get home I am going to run the scanner and see what it threw.
Just wanted to see if any of you experienced this.
Rampitt
Rampitt
uploadfromtaptalk1456184152051.jpg this was the error code I got.
Sent from my LG-H901 using Tapatalk
JUICEBOX
I don't read the script. The script reads me.
Pittsburgh
Is that from an app? Im really far behind.
Rampitt
Rampitt
anyone got any ideas on this?
chefred112
Tracy, CA
2005 QC 2wd
392 Hemi
clear it and see if it comes back...have you cleaned the throttle body lately?
Rampitt
Rampitt
the light went away and never came back. I cleaned the TB a little when I swapped the intakes.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
It is best to remove the TB and use Brake cleaner and a tooth brush to clean the TB. Use chemical sparingly. And wipe dry/clean with a cloth. Then reconnect the battery and do the recalibration steps and you are ready to go.
Rampitt
Rampitt
Yeah I'll have to get around to this. Maybe this weekend
