Your truck gets air from 2 places ,that fender tube attachment picks up air from the area around the headlight,but it also gets air from the high pressure area in front of the tire.If you look close at the plastic panel that scoop attachment ties to on the fender,you'll see it also feeds down towards the front tire and is open at the bottom.Personally i think that's were it also picks up the most dust. I run a 3" ducted scoop from the lower valence on my Sport feeding my modded airbox,and i found the majority of dust picked up by the air filter seems to come from the factories bottom scoop.As an experiment i stuffed the bottom scoop opening full of foam,and noticed my airbox stays alot cleaner now,that was 2 years ago,and the piece of foam is still in place,lol
