Roloff
Canada
Lifter seized up on #5 looking for a list of all applicable parts including non related parts i should be replacing while im in there, that i will need to complete this job.
Here is what i have so far in my cart.
- Cylinder head bolts
- Head gaskets
- Manifold bolts
- Manifold gaskets
- Timing cover improved gasket
- Oil pump tube O-Ring
- Hydrolic lifters with mds ×16
- Cam with mds
- Cam n Crank bolt
Is there anything im missing? Also what are some good performance part companies that would sell all of the parts i require. Everyone seams to be out of stock with the hydrolic lifters...
huntergreen
Marine Corps Navy Badge
Check with moes a forum vender.
MoparBrent
Ontario
3.0L Hurricane S.O
Look into valve springs, retainers and such.
Get in touch with Matt at Moes performance on here. He has a good aftermarket cam and all necessary parts.
Also while you’re in there and into your engine, how many miles do you have on it? May as well do stuff like your water pump as preventative maintenance while your engine bay is open
R
Roloff
Canada
Thanks for the responses. Truck has 230k so water pumps a good idea. Already done timing chain n tensioners.
HammerHead
USMC 0313
Georgia/Florida
2019 4Runner
- Head gaskets
- Manifold bolts
- Manifold gaskets
- Cam with mds
- Cam n Crank bolt
I would put in Hellcat lifters with the MDS delete, custom Jay Greene cam with a custom tune.
ameer73
