Cam upgrade
spieg69
Tx
So I went with the Ams kit. It lacks some gaskets and some bolts needed for rebuild. I'm new to this forum but not others. I have worked on diesels for 16 yrs. This is my first gasser rebuild. Everything went smooth and runs like a champ. I'm getting the poo38 code that I never had before. I ran the truck for 20 miles cleared the codes and they came back. Do i need to replace the sensor or put more miles on it first?
S
spieg69
Tx
So anyone that has this issue turned out pcm plug clips that are garbage BTW weren't pushed in far enough..ended up with 18 electrical fault codes and shut down the truck. Pushed the clips in with a screw driver and all fine now
