Can evap system cause u0002 code?
Hesabiggin111
Oklahoma
4.7 v8
Ok I have a 2007 ram 1500 5.7 quad cab 2wd and it sputtered for a second the other day plus like 2 different random times the warning singer dinged but nothing on the dash area or over head did it say anything and no check engine light but I put my code reader on it and at first it passed no codes then I went a little deeper and found code u0002. So I ran through everything again still no check engine light but this time it failed. The evap modular failed. The only module out of all 8 modules to fail and still had to run the abs for codes to find the u0002. Is it possibly whatever is going on with the EVAP causing the u0002 code? Thanks guys for any help
Fatboy1989
