Cargo Light Question
Phillyrube
Flatistan
Is there any way to deactivate the cargo lights from coming on except via the switch?
huntergreen
Marine Corps Navy Badge
I guess you could pull the fuse. Why do you want it deactivated ?
Phillyrube
Phillyrube
Flatistan
Just dont want them to come on when locking or unlocking via the key fob.
Ramagain
Do you also have the horn disabled?
Only way I could think of would be to add a switch. The harness for the CHMSL is on the driver side A pillar. It has a green connector. I would splice it at the headliner half of the connector and run the wires into to the dash panel.
DRam01
NY
Curious about this also. Any particular reason you would splice at the "headliner half" specifically for the switch?
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
I'm going to take a guess that it's in case the wiring in the A-pillar is running something else, he doesn't want to chance affecting it.
DRam01
NY
Planning on upgrading the cargo light bulbs to high output LED bulbs so this is right up my alley. Installing a kill switch will allow me to only use them when necessary. Planning on tracing the + wire at the source and matching it up at the A-pillar/ Driver dash area.
