crackerjack1957
- Sep 26, 2015
- 2,045
- 2,452
- 2014 Sport 1500 CC 4x4
- Hemi 5.7...65RFE...4.56
Alpha can also screw some chit up if not careful.
Clearly the trans is a POS and who ever rebuilt it did a bad job I would contact ebay stop wasting your time yank it and send it even if you get it to work probly wont last long.
OOOR Sell it and buy a hemi
So your thinking alphas quicklearn or relearn could be the culprit? Im asking because im thinking of upgrading my 65rfe VB to the sonnax one and was wanting to use alpha as my relearn tool.Alpha can also screw some chit up if not careful.
Is it bad when you loose focus as soon as trannys are mentioned? Asking for a friend..
I'm sure you've probably looked at this already but does the main trans connector have any bent or corroded pins?
Not saying it is but you can change things with alpha that can cause havoc......that's why saving screenshots of data before changes are recommended to reverse just in case.So your thinking alphas quicklearn or relearn could be the culprit? Im asking because im thinking of upgrading my 65rfe VB to the sonnax one and was wanting to use alpha as my relearn tool.
Glad you got it figured out and working correctly
That's great!!Issue fixed. It was a shorted solenoid pack.
That's great!!
Which solenoid pack was shorted? I thought you had switched them at one point?
Thats great what a group, many minds together can fix just about everything!!!
