CEL P0171 Help please!
fatwombat
Connecticut
Hemi what else??
So I recently got the P0171 CEL on. I first thought it was my MAP sensor since I was getting a rough idle and the truck shut off on me. Bought a new MAP sensor and then five codes came in. one saying Bank 1 is lean, then the other saying Bank 1 is rich, then low voltage on sensor. I want to break things down and see if I can get this solved by tonight. There is no vacuum leak.
I am thinking:
Both O2 sensors
PCV Valve
Or I got a bad MAP sensor
Would like some guidance and support? Since I can turn no where else but the experts here!
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
When was the last time you did normal maintance on the truck?
fatwombat
fatwombat
Connecticut
Hemi what else??
I would say about 3 months ago... Not everything was done but most stuff...
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
When you put in the new senor was the battery unhooked? PCM reset done? Is the connection good and clean?
fatwombat
fatwombat
Connecticut
Hemi what else??
Battery was not disconnected but I did reset the PCM!
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Im courious if the new sensor got a spike in voltage when you hooked it up. The electrical systems on these trucks are sketch at best sometimes. Call the place you sourced the part from and tell them their new sensor is hay wire and needs to be checked out buy whoever supplies them. Get another one and have the battery unhooked to install the new one.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Im leaning towards that being your issue because you got both the bank 1 showing rich and lean at the same time and the only thing changed has been that sensor.
ramhunter9
P-Star Jeep Wrangler
P0171 1/1 Fuel Sys Lean
On top of this page we have trouble codes .
I will move this to the correct section for you .
fatwombat
fatwombat
Connecticut
Hemi what else??
I know but nothing helps me with telling me what the correct problem part is!!
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
I don't have access to my data, so pulling this from my ass. But the sensor low voltage is also tied closely with fuel. I think I would reset the PCM check MAP connections, clear codes and see what codes pops up. Good luck..
fatwombat
fatwombat
Connecticut
Hemi what else??
The thing is I replaced the MAP sensor with a new one and clear codes. Then 5 codes logged. So Im going with the MAP sensor went bad or was a bad one!
Redtruck-VA
Virginia
Makes sense, pls post the out come.
Thanks,
fatwombat
fatwombat
Connecticut
Hemi what else??
I will... I will be buying another sensor hopefully today!
