Changing 4.7 plugs
02ramboi
live oak florida
4.7 v8
Changing my 4.7 plugs this weekend I know I need a slim spark plug socket because a normal won't fit. Anything else I need to know or I will need before I do it thanks in advance
4.7 v8
Hi flow cat/flowmaster exhaust
7 inch lift/5 inch lift
20 inch falken wildpeak at3/33's
panoz3
Waterloo, IA
After you remove the coils but before removing the plug, use some compressed air to clean dirt out, you don't want that stuff falling into the engine. Also put some high temp anti seize on the plugs so they're easier to remove next time.
Sent from my XT1030 using Tapatalk
02ramboi
02ramboi
live oak florida
4.7 v8
Ok thanks I will make sure to do that.
4.7 v8
axshon
Aluminum heads: don't over tighten. Use an extension that grips the socket better than the socket grips the plug or you'll be fishing the socket out with needle nosed pliers. Do one in front first so you'll know for sure if the socket grip is right. Getting it back out of #7 or #8 is a PITA.
02ramboi
02ramboi
live oak florida
4.7 v8
Sounds like you speak from experience haha definitely will keep that in mind
axshon
Indeed! Just did that and auto trans fluid last weekend. Runs smooooth now
02ramboi
02ramboi
live oak florida
4.7 v8
Do you remember the gap on the spark plug.
4.7 v8
buckeyexx
Ohio
2016 Power Wagon
Should be .040. I believe it is also labeled under your hood
02ramboi
02ramboi
live oak florida
4.7 v8
Ok cool
4.7 v8
02ramboi
02ramboi
live oak florida
4.7 v8
Thanks
4.7 v8
