Paul Prince
Good evening folks. Need some help please. I have a 3500 with Cummins and Aisen transmission. I did a fluid and filter change this evening. I went to start up truck when done and after wait to start light went off a 4 wheel dr temporary disabled came on the screen. It Was only on for 2-3 seconds. Never seen it before. After starting it up the check engine light stayed on. I only ran it for a few min and then drove home from my Dads barn to house. That distance is only about 2/10 of a mile. I haven’t check the fluid level yet because it wasn’t up to operating temp. The dealer said it should take 7.2 qts to fill back up. I believe I’ve read that on here as well. I only put 6.75 qts in so as to not over fill. I was real careful in trying not to touch any wiring or connections when pan was off. Does anyone have a clue here? Thanks
