CHML leak fix re-do
WY-Dave
Air Force
Cheyenne, WY
6.7 CTD
After joining this forum back in '18 jsut after getting the truck, seen alot of posts about leaking around the CHML. When replacing the bulbs with LEDs, I threw on a bead of silicone. A couple of weeks ago I noticed
SO off came the light, and what a mess the silicone left.
noticed that the harness from the truck had connectorized splices for what I am assuming is for the cargo cam (I cannot retrofit because of the base stock radio).
I took the splices out and taped the remaining harness .
A sanding sponge with a course(cheap) microfiber cloth wrapped around it and some goo-gone.
I gorilla taped the opening that I could feel the headliner.
Put a small bead of the black windshield sealer/adhesive on the foam "seal" and screwed it down
JW2 Innovations
Supporting Vendor
Sparta, TN
2016 Ram 2500
@WY-Dave I haven't tried this way when I sealed up mine, so hoping you don't have to redo again. IF it doesn't work, you might want to try this route: LINK
WY-Dave
WY-Dave
Air Force
Cheyenne, WY
6.7 CTD
I have some of that weather seal ready for the next time. I have LEDs in so hopefully it will be a long time before I have to get back in there
