Clayton lower control arms on. Pics.
VelocityC6Z
Maryland
That's interesting, your zerk fittings are on the same side, mine are on opposite sides.
definitely recommend greasing them before you put them on. I didn't, and had a bear of a time getting my grease gun on the driver side on top. I ended up jacking the passenger side up about a foot to expose enough of the zerk to get the grease gun on.
hind sight 20/20 I should have greased before i put them on.
I definitely noticed a difference in stability.
ram1500rsm
Trabuco Canyon, CA
The ones that came in yesterday have the zerks on opposite sides as well. and i had to cut a small corner on the upper bracket so the zerks will fit.
50267947211_146d867332_k.jpg20200825_083248 by RAM RSM, on Flickr
50267947221_7487bc0095_k.jpg20200825_090243 by RAM RSM, on Flickr
50267747118_06dadf1d13_k.jpg2020-08-25_12-17-15 by RAM RSM, on Flickr
50268020888_275c523003_k.jpg2020-08-25_01-34-40 by RAM RSM, on Flickr
VelocityC6Z
Maryland
I need to take a look to make sure mine aren't rubbing, I don't think they are... I almost cut a small chunk out just so I could fit the grease gun over it easier... I still may do that.
My control arms show up tomorrow. Can't wait to toss them on over the weekend, depending on the weather. This hurricane / tropical storm looks like it may hit the east coast and ruin my plans.
VelocityC6Z
Maryland
How's your ride been from the core end links? Curious if you noticed it too, or if I'm just noticing a placebo effect.
Have you considered the front sway bar end links? I can't find much, mevotech, moog, and ac delco all have zerk fittings on theirs. They're also between 20 and 30 dollars on rock auto, but don't seem to affect the front ride height difference and geometry of the sway bar since they don't extend the factory length.
DILLIGAF
Canada
Well after much research I settled on these as well... looking forward to getting them installed. My OEM are in bad shape from offroading and my lift.
My" Superlift never came with the drop brackets. Does anyone know what lengths I should set them at with a 4" lift ?
6.7CumminsDrvr
The Dude abides………
Georgia
My 4” came with the rear brackets, I’ll see if I can measure the distance from the OE mount to the mounting location in the bracket.
DILLIGAF
Canada
I just emailed Superlift and see if I can just buy them. But not sure If I even need them now since my new control arms are adjustable.
6.7CumminsDrvr
The Dude abides………
Georgia
I just emailed Superlift and see if I can just buy them. But not sure If I even need them now since my new end links are adjustable.
reading thru this thread, are you talking about the rear end links or control arms?
DILLIGAF
Canada
Mine just showed up.
Just had to get a grade 8 bolt and Thread a 7/16-14 hole for the factory bracket.
Also got new 10.9 bolts while as was at it.
VelocityC6Z
Maryland
You'll have a blast then for sure. I noticed the biggest difference turning on washed out roads.
I can't wait to go to 4.56 gears. After headers, an intake, and tune, I think the 4.56 gears will have the most noticeable change in driving performance.
GIJoe2010
No sh*t, there I was . . .
Killeen, TX
Where did you get the LCAs and how much???
RVA Ram
Richmond, VA
View attachment 44842820200825_083248 by RAM RSM, on Flickr
View attachment 44842920200825_090243 by RAM RSM, on Flickr
View attachment 4484302020-08-25_12-17-15 by RAM RSM, on Flickr
View attachment 4484312020-08-25_01-34-40 by RAM RSM, on Flickr
I installed mine the opposite direction. The right hand side bracket is open on the back side and it seems like the left hand side bracket has plenty of room.
Ftank
