Code P0301
Randy-2021
Manitoba, Canada
having a problem with my 2016 RAM 1500 5.7 Hemi
Code reads P0301 - Cylinder 1 misfire, changed spark plugs, swapped coils but the code is still there
Truck has a rough idle, also hard on fuel
Check engine light was on, but is off now but fill reading the code
I’ve had previous problems with it going into Limp mode, took it to a dodge dealer ship, ended up being low on oil i guess but ever since then, when the truck is getting low on oil or gets to half a tank or less of fuel, it will go into limp mode
mtofell
My misfire code resulted in a new engine due to some bearing failing and throwing metal throughout the engine. Statistically, your issue is much more likely to be something on @rzr6-4 list but those flashing CELs can be bad.
Hagar1
Ontario Canada
2012 Ram 1500
First thing, do a compression test.
Burla
2010 Hemi Reg Cab 4x4
I don't know what to say about those conditions and going into limp mode, usually not related to cam/lifters. If you end up needing a cam, those conditions could still be present. I'd take it to someone who could convince me the were hemi mechanic number one in your area.
mtofell
Probably should have added that my flashing CELs only came up under moderate/hard acceleration. I also got some really bad shuddering at times but never limp mode. Fingers crossed you don't have what I had.
JUSTANORMALGUY
NW OHIO
5.7L HEMI
SIMILAR ISSUE BUT GETTING P0302 CODE. DID PLUGS AND COILS NOT GETTING P0302 ANYMORE, BUT NOW GETTING P0300 CODE? I AM BY NO MEANS A MECHANIC. I CAN DO BASIC MAINTENANCE. IF I WERE TO NEED VALVE TRAIN WORK OR GASKET WORK IM SCREWED. ANY TIPS OR TRICKS TO TROUBLESHOOT WOULD BE APPRECIATED.
R
Randy-2021
Manitoba, Canada
- update - Truck has a loud ticking sound coming from under the hood driver side as also that i forgot to mention, changed the coils and still the same code.
Hate to ruin your day,but you might be a candiate for a new cam and lifters.Did you ever do a compression test as suggested above.
Steve58
