Cold air intake gains
2010 Infantry Vet
Butler pennsylvania
Since I will be getting a greene tune soon, are cold air intakes wofth buying for HP gains? Anyone have any dyno numbers? I have heard the factory design is good, and just replacing the stock filter with a better flowing one is the best route. Lets hear your thoughts.
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
I wish you could kust buy the tube that connects the air box tobthe throttle body.
Then I would do a drop in filter and do the diy fresh air scope like I did on my Cummins.
Or get a Vararam.
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
Think Jay recommends the Fastman ported TB over aftermarket CAI......give him a shout.
crazykid1994
I run a s&b intake but the factory is pretty well setup if you use a drop in filter. I changed mine for the looks and the fact that I may do cam and headers down the road and figured it’ll help with those mods
Edit: can someone share the post about the intake box mod with the dryer tube
2010 Infantry Vet
2010 Infantry Vet
Butler pennsylvania
Or get a Vararam.
If I cant find a tube, i might fab one out of thin steel tube. Tig weld it cone style.
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
Not sure anyone makes one but they should it would be a easy sell since the newer airboxes flow well enough for most engines.
crazykid1994
McBroom
Denison Tx
Hemi 6.4L
2010 Infantry Vet
2010 Infantry Vet
Butler pennsylvania
HDHNTER
US AIR FORCE VETERAN OEF - OIF
SC
5.7L HEMI
I opted for an aFe Momentum & held off on buying until after the Outlaw cat back & Pulsar. Very pleased w/ how it complimented the other mods, noticeable improvement throughout the curve. c55c3a21a9b1f22a3cc748b9837c105d.jpg
Ramm5.7
So Cal
2019 Ram 1500 Classic Bighorn
I was VERY happy with my oem box, aem drop in filter and 3"add a tube. Lots of pull with pedal comm, pulsar and fastman tb.
I swapped to a S&B, man what a difference!! monster filter(makes WAY more noise at wot than oem with add ons) wont stop pulling on top end. Excellently made, stout and solid
2010 Infantry Vet
2010 Infantry Vet
Butler pennsylvania
S&B looks almost identical to the stock housing in your pics. They just used a smooth plastic plastic pipe, verse the ribbed poor flowing stock tube. Looks like that is the only difference. Its gonna be a while, but I think I am going to just tig weld a cone stainless steel thin wall tube to connect from the TB to the airbox.
Thank you for posting both of those pics!
Ohio5pt7
Ohio
I keep hearing the vararam is the best. IMO it looks the best but does it really have an advantage I do mostly highway driving 120mi a day.
dearchristopher
Galveston, TX
Do you have a pic of it?
It's pretty unanimous that its at least very near the top in terms of best options for the 5.7
in order to see gains from a CAI you have to tune your vehicle. the added air density from a CAI gets tuned out when the PCM starts adjusting fuel tables. that's ANY CAI you get. once you get a tune that can actually do something with the added air volume/temp, thats when you see the vararam shine. i really like mine, flows great and IAT's are lower than stock by a decent bit.
Ohio5pt7
Ohio
Thanks for the info
McBroom
Denison Tx
Hemi 6.4L
People say that there’s nothing like this for the 6.4 BTE( big truck engine) because the throttle body is at an angle towards the passenger side. I think an angle tube is all that would be needed in order to make it work.
Blue Streak Pearl off-road
