ToxicFire
So I put a full brand new battery in it after truck sat overnight and fired it up and it still did the same pause in cranking.Gas and Burla is right. Check the battery at night, if its full disconnect it till the AM. If it fires up you got a draw... fuel relay on the TIPM is pretty common. So common they make a bypass cable to prevent having to replace the entire unit. (Fuel relay is soldered to the board).
Sent from my SM-N960W using Tapatalk
