Computer Issues
leelatta
alabama
I have always had a problem where you could not have 2 phones plugged into the USB - C plugs at the same time it would always switch from phone to phone.
Now I had my rear passenger TPMS sensor go out, took it to a shop and had it replaced. A couple of days later the rear passenger TPMS sensor was showing out then a couple of days after that the driver rear started working and the passenger rear went out. On top of that on the display where it shows the MPG that you are using there is a number in the right corner that fluctuates from 0 - 99 dictating your fuel consumption, it has disappeared. Any help would be appreciated. Anyone having the same issues.
Sherman Bird
Houston, Texas
I use a calculator on my phone and a scratch pad at the pump to determine my MPG. Always have, despite having that info displayed to me. I also use an old fashioned tire gauge to know what my tires' pressures are, in spite of having THAT info displayed.
I frequently find the MPG calculator in my vehicle's info system is off by a remarkable amount.
