Mr. Baseball
I had to replace water pump and thermostat on my '98 Ram 5.2. I saw video showing coolant drain bolt on an '01 that is under water pump on passenger side. When I removed it nothing drained but when I removed water pump bolts coolant poured out.
I hope someone can help. Is it the drain and mine is clogged or is '98 different from '01. Looked exactly the same as '01.
I really appreciate any help and knowledge about this. Thank you.
