Coolant temp constantly bounces around.
ACE2014RAM
Wapakoneta,Ohio
Hello all. I bought a used 2014 Ram with the 5.7L. Hemi. Roughly 80,000 miles on it. When I first bought the truck the temp seemed to bounce around a little bit with the factory thermostat. I thought maybe it was going bad so I replaced the thermostat with a 185 degree thermostat. Now the temperatures go anywhere from 180-210 degrees depending on load demand. So far I have put 2000 miles on it and it’s still doing the same thing. I haven’t seen it go above 210 but I feel like it might if I push it hard enough. Anyone else seen this issue before? Thanks In advance for the help.
Dinky
Oregon
Have you removed the active shutter?
Burla
2010 Hemi Reg Cab 4x4
Or radiator fan or clutch, likely one or the other. Look up fan upgrade here.
Maybe try a differant thermostat,i've had a couple brand new thermostats lately,that were duds right out of the box
Burn2k12Ram
Reno, Nevada
If replacing the factory 203 with 185 thermostat doesn't one need to tune for it? Because isn't the computer trying to allow it to get warmer to match the 203?
crazykid1994
Factory 203 will run up to almost 220° due to the ags. When opened it’ll fluctuate back down to 203. The 185° may not be the best idea when not tuned just because the engine may run a bit richer to bring temps up and the ags may stay closed more to keep temps higher.
They go into closed loop at roughly 160,so as long as it's over those temps,it shouldn't run rich. I've ran 180 t-stats in several late model Chryco's and never had any issues with them running rich,with-out tuning or playing with the fuel trims,so i doubt the thermostat is causing it to run rich,or would explain his fluctating temps.If his water pump is good,and the rad isn't plugged (which i highly doubt,as the temps wouldn't drop if the rad was the issue),it kind of makes you wonder if his replacement t-stat isn't a bit of a dud.I've ran into 2 new 180 t-stats lately that were duds right out of the box,one was even a high flow Milodon thermostat.
Burn2k12Ram
Reno, Nevada
And the shutter will almost remain closed to try and
Great points really crazy the lack of QA on parts now days even from reputable companies.
turkeybird56
Central Texas
Sounds like a thermostat if all other good. MY DT 19 Truck, with the E Fan, runs 199-222 F, friggin annoying. I did take it in to Dealer and they said all Sensors were OK so "They" ordered a new 850 W fan, 1 Feb 2022. Not know which slow boat from wherever it is? LOL. Not know when will arrive.
I would put in another stat first, if U R OK with the radiator functioning properly, water pump good and proper coolant mix. Just IMHO...
ADDED: OP, here's a thought. Did U burp the system after putting in new stat, ie., to get all air out of system? That could be an issue also.
turkeybird56
Central Texas
Definitely keep receipt if buying parts these days, LOL.
turkeybird56
Central Texas
I learned that with my GMC. Lets see, bad new wheel hub, bad new EGR valve, bad new fan clutch on my older RAM lol.
Oh Yeah, why if I "buy" ne thing of a higher value, I always use a CC, easier ref refunds etc.,.
Dusty
Rochester, New York
Under what kind of driving conditions does this occur?
Frankly, I'm really thinking it is acting normal. I still have the factory thermostat and when I tow my 7000 lb. tractor and trailer I typically see a fluctuation of sometimes 10-12 degrees, especially going up steep grades. Some of that is likely due to increase in transmission temperature. Around town it seems more steady depending on the length of the drive and ambient temps. In any event, in this respect my DT '19 acts exactly like my previous 2010 and 2014.
Coolant temp overshoot is not uncommon in just about any system when you increase the load.
Regards,
Dusty
2019 Ram 1500 Billet Silver Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33-gallon fuel tank, factory dual exhaust, 18” wheels. Build date: 3 June 2018. Now at 73766 miles
turkeybird56
Central Texas
Regards,
Dusty
I am not 100% sure OP actually has a problem, as my truck will run mighty warm when towing, especially down here in TX. But OP could put in a slightly lower thermostat and that may help, provided all the systems are working properly.
A
ACE2014RAM
Wapakoneta,Ohio
Regards,
Dusty
Driving condition were 85ish degrees. Straight truck, no trailer running about 75mph up and down some pretty steep grades. With 185 degree thermostat i didnt figure it would get up to 205-210 but maybe im mistaken.
A
ACE2014RAM
Wapakoneta,Ohio
so i have no reason to worry about my engine running to rich? i wasnt aware of this if thats true. Maybe just need to tune my fan to a lower temperature? And what is AGS? maybe a dumb question
Active grill shutters,if you have the 8 speed odds are you have the shutters.
Burn2k12Ram
Reno, Nevada
on first startup think of it like closed window blinds allows the truck to get up to temperature then opens when truck up to temp.
Mister Luck
cassis tutissima virtus
WEST COAST
5.7 V8
You know auto transmissions have their own coolant thermostat ? Meaning it will affect your coolant temps also.
