ram1500rsm
- Joined
- Jul 24, 2018
- Posts
- 4,891
- Reaction score
- 5,413
- Location
- Trabuco Canyon, CA
- Ram Year
- 2014
- Engine
- Hemi 5.7
Definetely like Redsrt4me indicated, if you can add a large enough washer to protect the bushing from the edges of the mount that will be gold. As a reference this is the gap i have in my mounts with Clayton and that's torqued to 195ft/lbs. Like the JJ side on the Core ones there is a mile of clearance between the mounts and the bushings can deflect side to side without any rubbing. You can also upgrade those Core T3 to T4's and you won't have to worry about those poly bushings ever again. It's not Core's fault.., any type of poly bushing where the sleeve sits flush with the bushing will more likely have the same fate in this application.
Lower Frame side
2020-12-24_09-08-51 by RAM RSM, on Flickr
Lower Axel side
2020-12-24_09-08-59 by RAM RSM, on Flickr
Upper Axel side , and it looks the same on the frame side as well.
2020-12-24_09-09-07 by RAM RSM, on Flickr
Lower Frame side
2020-12-24_09-08-51 by RAM RSM, on FlickrLower Axel side
2020-12-24_09-08-59 by RAM RSM, on FlickrUpper Axel side , and it looks the same on the frame side as well.
