Anyone have any issues or concerns with thier CP4 yet? Also why would FCA go to an inferior system should have stayed with the CP3
Industrial Injection, and there may be another.wonder if there is a kit to swap them yet for Cummins
There's a TSB (Ram-TSB#18-060-20/ NHTSA_TSB#_10180256) that you need to read if you have to flash the ECM on the HD trucks because there's two types of pumps now. The TSB help you identify the CP4 pump used on the truck.
That would indicate there's a new revised CP4. The "older" RAM CP4's (Asymmetrical) are changing the lobes back to the style that the CP3 used (Symmetrical) with the new CP4 having Symmetrical lobes. Linked is the TSB, also attached.
https://static.nhtsa.gov/odi/tsbs/2020/MC-10180256-9999.pdf
It is a less aggressive profile. It would appear that all of the flaws of the CP4 design remain, including becoming a glitter gun when it fails.Questions that come to my mind? .......... Part of the issue with the old design was fuel from the Crank Case of the pump (for lack of a better name to call it) was pumped to the rail, so after a failure all the Flack is pumped to the rail. I believe the CP3 did it a different way? Try as I might I couldn't find a photo of the new CP4 cam? Sure would like to see what it looks like.
Yes, well aware of the CP3design. I have read/seen nothing that leads me to believe they have gone away from the inferior roller setup. Everything points to just a less aggressive cam with a symmetrical design.The CP3 has a puck system under the pistons (3). The CP4 has a single roller under the pistons (2), that rides on the cam. The original poster mentioned the new CP4 is more like the CP3, I wonder is it just the cam that's changed, and the "roller" remains, or did the roller go away in favor of the puck? The whole way the pistons are actuated in a CP3 is different than the CP4........
same here no mark my truck was built 06/20Just checked my 2020 Ram 3500 4x4 with the 6.7 Cummins HO Diesel to see what pump I had. There is no mark at all on the upper part of the pump? My truck was built on 7/20/2020. Did they make changes again?
I used cheapo howes for the first 5000 miles because i didn't know about the cp4, but the current 5000-10000 mark I've been on a hot shot regimend. Edt w/lx4 and also stand alone lx4, that stuff is awesome and very lubey. I just hope that in my first 5000 miles that the cheapo howes I used kept it from scratching up in there.New to the forum. Hello.
I recently sold my 1996 2500 12 valve, that I bought new, way back when. 26 years of bullet proof reliability.
The wife and I are retired now and we decided to upgrade from the Lance slide in camper, while towing a utility trailer with our motorcycles, to a toy hauler. Now that we are free to wander further out, we upgraded the tow vehicle as well.
After a little research, I went with a new 2500 Big Horn with a 6.7 TD.
While doing the research I missed the part about the problems with the CP4. I've been gathering as much info as I can about this, after the fact, and found that in the US, there are 7-10 failures per 100 units. In Europe, these pumps fare much better with 1 failure per 100 units. The reason given for the difference is, European Diesel has a much greater lubricity rate than Stateside fuel. A possible solution to extend the longevity of the pump is with proper additives. With just 1500 miles on the new truck I've started an additive regimen using Hot Shot products. Time will tell. If it works...it was cheap insurance.
I'm not associated with Hot Shot in any way. I post this as possible useful information. There are a number of youtube videos concerning the use of this stuff, more than a few from people that use their trucks commercially, and rack up some heavy mileage. Here's one video. A podcast actually. It's a half hour long but...be patient, it's packed with valuable info. Granted, it's from the manufacturer and is self serving. If accurate, it could save someone a boat load of money.
Here ya' go...
(339) CP4 Failures & Lack of Lubricity - YouTube
